Is there a difference between auto and manual consoles?
EW1BH27
Canada
The lower half on the drivers side is cut out to accommodate the 4 speed boot, not cut on automatics. Picture from ebay, that company also sells the template.
Bstoker87
Colorado
You can cut the lower driver side of the console and buy a manual top plate to convert a auto console.
Righty Tighty
Sahuarita, AZ
Thanks. I actually have the opposite problem. I have an auto car with an auto console that’s got some wear. I have a manual console in much better condition that I would like to install in place of the auto one, wondering if the manual will fit over the auto tunnel hump with no issues.
If it will, the plan will be to swap top plates.
pschlosser
Santa Rosa, California
Yea, I expect a manual lower console to fit just fine over the automatic shifter. As you said, swapping the upper woodgrain plate may be the only structural difference.
Bstoker87
Colorado
It should work fine if you buy the correct auto top plate, i have a nice 70 auto top plate if needed.
Righty Tighty
Sahuarita, AZ
Thanks for all the replies. After looking at this image and comparing it to both of my consoles, I realize I have two auto consoles -- one with a 4 speed top plate. The reason I was asking about the differences was because they looked identical to me, and that's because they are.
I'll swap out the current console for the other one that's in better condition and switch top plates, so I have an auto top plate.
EW1BH27
Canada
Glad it's sorted out. Depending on it's condition that 4 speed top plate could be desirable.
