Leaf Springs
BH23L4B
Is there any difference in spring length between a stock Dana 60 and a set found on a 73 H code 4 speed Cuda? Someone previous to me installed a Dana in my cuda and the car sits higher and the leafs contact the rear valence. I'm trying to figure out why.
Thanks!!
MOPARMITCH
Friendship,Maryland
They should be the same length. The issue probably is that they have either more leafs or are stiffer causing your dilemma. How much weight is in the car?? Engine, Interior, Etc. ?
BH23L4B
It's in stock trim. No lightened anything. But they do look new and the hangers are definitely aftermarket as well as the rear shackles. I hate using that word. So 1980's. It has been suggested that the springs may be a super stock setup. Not sure.
If the aftermarket shackles are longer than stock, the spring has more room to flatten out. That effectively makes the spring longer, which will cause the clearance problem. The difference in the spring packs between the different spring rates are not in the length, but in the arc and thickness.
Adrian Worman
England
Yep.
Are the leaves on the passenger side any different to the drivers side? Number of leaves, thickness etc?
mmissile
Macomb County Michigan
Maybe the car has longer front boxes for S/S springs. That'll move them back into valance....as well as change the wheelbase and drive-shaft length.
BH23L4B
mmissle nailed it. Turns out that the car has Mancini racing front hanger extensions and superstock springs. Thanks for the help!!
Moparparts
I have a few sets of stock Cuda 340 leaf springs if interested PM me
