challengingjab
I'm having trouble with engine stalling after warm up when dropping in gear. Runs fine for a short drive then after stopping fo a few minutes and leaving motor run when put in gear motor dies. does this every time I restart unless I hold gas pedal down pretty far .And then the car will lunge and take off untill I stop again and then same thing happens again. I have had a couple of guys tell me that the coverter is not releasing when engine coasts back down to idle. And when I go to put car back in gear it is just like letting out the clutch on a stick with trans in gear and engine at idle. and converter needs replaced. makes sense to me !! So here is where the problem starts. I called jegs about a new converter. since I have installed a mild street comp cam and a cheetah manual valve body. I decided to go with a mild stall converter. I am working with a 1970 chrysler 440ci (375HP) at start and a TF727 Trans.not shure what year. I gave this info to their tech and he told me he needed to know if it was a locking trans and if the engine was a internally or externally ballenced engine i can check the engine but don't know about the transmission. I thought all TF727 TRANS were non locking and if not how do you tell. Plus I can't find a converter listed for a locking TF727. Does anyone know for certain if there is a locking 727 ? I thought only overdrive trans were lock up trans. Please help anyone!!
