looking for kill switch
Avalanche
Massachusetts
I'm looking to install a kill switch in my 70 challenger with electronic ignition.
Can someone recomend what would work.
You need to do 2 things. First, get the inside hood release from a new Challenger to prevent someone from opening your hood from the outside and bypassing a kill switch. Second, decide if want a compltete alarm set-up, or just a toggle switch.
You can get alarm set ups for under $100.00 .
You can easily install a hidden kill switch inside your car. In one of my cars (a Ford) I cut the Ignition starter wire in the column harness spiced in some long wires and added in a hidden toggle switch. the switch must be on to enable cranking; on another I plumbed in an extra switch to the neutral safety switch. This one is a common brake light switch mounted on the emergency brake pedal; to start the car must be in neutral and the E-brake must be off or the car thinks its in gear and will not crank. You could put a hidden switch in the neutral safety switch in an Auto trans car too... using the center wire(?) off the three prong switch...These seem overly simplistic but I know a lot of guys don't have the skills to run down a NSS problem.
The reason I recommend an inside hood release( I don't think they came on the 1970) is that these have old school ignition systems. You can put all the kill switches you want but if all they have to do is have a piece of wire with alligator clips on both sides to jump power from the battery to the coil, they won't work. Now newer cars with electronic ignitions and computers are a little more complicated......
Avalanche
Massachusetts
That's a good idea.
Will a any year newer challenger hood release work ?
Is it just the cable mechanism, or do you need the latch also?
Thanks,
Fred
sheetmetaldan
Acushnet Massachusetts
I put an inline fuse with a slo-blow 30 amp fuse in place of my bad fusible link. Just remove the fuse sort of acts as a low buck kill switch. I did this not for the benefit of a kill switch, I just didn`t want to spend the $20 at Year One for their link, but I do like the idea of being able to pull the fuse for a little extra protection.
True, but you have to open the hood to do it. If you have an inside hood release, you just lock the door. If someone really wants to steal your car, they probably won't have to start it. Tow truck anyone?
Or just use a micro switch to ground the - coil wire to the tach , no hot wire bypass will make it start hood open or closed
Diagram ?
there is a wire to the tach , grey I recall , jump splice or solder a wire into this lead , run it to a hidden switch & from the switch to ground , this will prevent most ign from sending spark except MSD with a seperate signal for the tach
Avalanche
Massachusetts
Ok, but I have a standart cluster with no tach.
If I add an aftermarket tach will this still work?
As you can read, I'm not an engine guy, more of a body man.
no prob , you can run a wire off the negative coil terminal directly to the switch & ground it through a hidden switch , no tach needed
73 kooda
Las vegas,nv NATIVE
What about running a switch between your ammeter????.... If that isn't connected, you aint gettin power to anything! Or am i wrong and can you still bypass it... My experience is yes if they want your car, theyre gonna get it..these are to keep the 17 yr old with a screwdriver from stealing it!
