Peter Fonda
- Joined
- May 31, 2020
- Messages
- 5
- Reaction score
- 4
Hello all, I'm a proud new owner of a '73 Cuda. Have been busy going through replacing all of the harnesses, front and rear lights were a breeze. Main dash harness seemingly went well, everything looked good, but need a few pointers below, any help would be appreciated! Glad to be part of the group! As a side note, I'm waiting on new Dakota Digital Rally gauges, I currently have most of the gauge wiring unplugged as I currently have a Non-Rallye setup.
Peter
- Turn signals worked before the harness swap, switched to LED bulbs, and also switched out both flashers. Have tried two different directional steering column sets, both do not work (one was the original) yet the ignition light and hazard lights work
- Put in a new retro stereo, wiring seems correct, but when the radio knob is off, the dash lights and console shifter indicator also don't turn on. When the stereo is on, they also turn on
- Put in a new under-dash A/C harness, can't figure out where these two connectors go? (blue and green)
- Coming off the brake light switch, where do this connector run to with two blue wires?
- horn works, but only when you put the key in the ignition, when you turn the key, horn stops working...
Peter
