Offset question
PlmCzy70
Florida
does any one know what the offset was on the factory Chrysler Ralleye wheels. I’m going with 275’s on the rear so I think right around 0 mm would be best. I see a lot of the cars on the site have the rally wheels so if you do, what’s the offset on yours?. my car has no mods at all.
15'' x 7''
Specifications:​
Part Type
Wheel
Product Line
Wheel Vintiques Chrysler Rallye Wheels
Back Spacing
4.25 in (107.95 mm)
Center Cap Included
No
Hub Centric
No
Lug Nut Seat Style
Conical seat - 60 degree
Package Depth
17.70
Package Height
8.30
Package Width
17.00
Part Category
Replacement Parts
Part Fitment
Universal
Primary Wheel Color
Silver
Quantity
Sold individually
Shipping Weight
26.70
Valve Stems Included
No
Vendor Part Number
56-5712044
Wheel Bolt Pattern
5 x 4 1/2 (114.3 mm)
Wheel Construction
2-piece
Wheel Diameter
15 in (381 mm)
Wheel Finish
Gloss Black
Wheel Material
Steel
Wheel Offset
6 mm (.2362 in)
Wheel Type
Car Street Wheels
Wheel Width
7 in (177.8 mm)
Specifications:​
Part Type
Wheel
Product Line
Back Spacing
4.5 in (114.3 mm)
Center Cap Included
No
Hub Centric
No
Lug Nut Seat Style
Package Depth
9.50
Package Height
17.70
Package Width
16.50
Part Category
Replacement Parts
Part Fitment
Universal
Primary Wheel Color
Silver
Quantity
Sold individually
Shipping Weight
28.10
No
Vendor Part Number
56-5812042
Wheel Bolt Pattern
Wheel Construction
2-piece
Wheel Diameter
15 in (381 mm)
Wheel Finish
Gloss Black
Wheel Material
Steel
Wheel Offset
0 mm (0 in)
Wheel Type
Car Street Wheels
Wheel Width
8 in (203.2 mm)
According to Challenger RTA's post above the 15x7 has 4.25" backspace with 6mm offset. I think this is a factory spec, but I’m not sure. 6.5” may have been the original width. The 15x8 has 4.5" backspace with 0 offset. This is an aftermarket spec that was never available from the factory but many owners now prefer this for the wider look it provides. No factory wheel from the era had 5.5" of backspace on it.
Backspace and offset chart for most standard wheels below.
I have a 1973 CUDA and the factory wheels had a 4.5" offset. I had to order American Racing wheels with a 5" offset to mount 255's on the rear as the passenger's side tire made slight contact with the wheel well with the original factory wheels.
I have a 1973 CUDA and the factory 15 x 8 wheels had a 4.5" backspace. I had to order American Racing wheels with a 5" offset to mount 255's on the rear as the passenger's side tire made slight contact with the wheel well with the original factory wheel
There was never a factory 8" Rallye wheel made.
It will need to be custom and will not likely fit without rolling the fender lips.
Still a 275mm section width tire may still rub cornering on the leaf springs or inner fenders if you are looking to use them at stock height.
No air shocks ! New springs with a little more arch.
I run 15"x8" Rallye's on the rear of my Challengers with a 4-1/2" back space and 295 rear tires with no modifications and all stock factory suspension. It is close but nothing rubs anywhere.
My
My springs in the rear don't quite have the arch required to run 275s I run 255's with a 5" backspace.
I’m running a 245 now in a 14 inch wheel so go into a 275 is basically a little over an inch wider. My Crager mags are the reverse mags with probably about 50 mm negative offset they do not rub in the back so I think I’d be safe with a zero offset With a 275 wheel. I can only hope. but going to a zero offset will really move that tire in away from the wheel well opening towards the leaf spring of which I have lots of room
Looks good and really fills the wheel well. Have you ever tried mounting that rear on the front? I'm hoping to run same size front and back and would be great to get 295's on both ends.
No, I have not tried, but 295’s are not going to fit on the front and not look very good that wide on the front.
If you put any weight in the back and also don't like the factory droopy rear springs. you will need to get the rear up.
Otherwise hitting dips with weight in the car, like a friend or 2 will cause the unmodified fender lips to contact the tires.
Again, do it properly with springs not air shocks.
I have owned these when they were new and only the T/A had the rear in the up position.
Run the air pressure low also. The tires are so much larger than factory that the ride will be very stiff unless you lower the pressure try 24 psi to start and adjust from there in the rear.
I use a 15x10 wheel with 5" backspace (don't know the offset) on the rear of my Challenger with a 26x12x15 (305/45 in metric terms) using a 1" leaf relocation kit and B body housing. All the change in housing does is change back space requirement. With the stock E body housing, you might need 5.5" backspace instead.
Front is 15x8, 4.5" backspace with a 26x10x15 or about a 255/50. Fits in all ranges of motion without contact anywhere. I do have the fender lips rolled though.
For fun, I tried putting the rear set on the front. 5" back space in a 15" diameter rim won't fit up front because it hits the control arm. I had to space it out .25" to clear the arm. This will smash the fender, so this isn't working without significant mods. However, I have seen someone running a 315R18 tire/rim combo on the front of a Challenger. The larger diameter wheel allows a larger backspace that pulls the tire away from the fender and in closer to the frame without hitting the control arm. But to do this the rim spacing has to be spot on, alignment has to be perfect, and fender lip must be rolled for it to work.
