Radiator overflow hose
bc3j
Cleveland, Ohio
Wondering if anyone knows where the overflow hose is supposed to exit the radiator frame. I currently have mine running across the top of the radiator then over to an indentation just below the battery tray. Directly below the indentation is a small hole about the size of the hose and I used that location. There is another hole directly below the driver's side edge of the radiator with a larger hole. Just guessing where it should exit. Couldn't find anything pertaining to the overflow hose in the FSM. Hoping someone will have the answer.
My radiator is aftermarket and the petcock is perpendicular to the radiator on the passenger side. The holes in question are on the driver's side.
