Rear Tires Turn When Trans is in Park
money pit
On my 70 Barracuda with a 727 Slap Stick I noticed I can turn the rear tires by hand when it's in park. It was like this when I bought the car. I had the trans rebuilt because it was leaking so badly (cheaper to rebuild than a re-gasket/seal). The car still has the same problem. Is there an adjustment to the linkage? Internally, isn't the parking pawl supposed to lock the trans from turning? Trying to get these safety issues resolved. My Trans guy is a Chevy guy and may not know Mopars that well. Thanks
if you have an open diff the tires will turn opposite direction , is the driveshaft turning ?
The tires turn in the opposite directions. The drive shaft doesn't turn. If the car is on the ground, does the trans keep the car from rolling? Thanks
When off the ground, the axles and their gears are rotating around the spider gears in the differential. When on the ground, the rear tires shouldn't move. At least not much. If the tires do not turn when off the ground and the car in park, that would indicate a Sure-Grip.
Thanks. That's what I thought. I had a Camaro with posi-traction and it did what you and others described. That's why I was confused.
