Shock tower measurements
AUSTA
PERTH WA
Anyone have the shock tower hole to hole (shock Bolt) center measurements for a 70 Challenger
Thanks Mark have that but it does not show tower spacing.
All the heights & spacing between the rails are right ,it had a slight hit in the L/H front i think there is a slight twist towards the inside will wait for some more feedback before welding inner fender
I am at 34"
My engine valve covers are in the way so it is hard to be exact, but I got 33 & 7/8.
Thanks ADAM i made some large calipers to go over the engine on my original A66 comes up at 34 same as the TA i am restoring good to weld.
My measurement was from the centre of the shock shaft to the centre of the other one it may be different if measured from the centre of the shock shaft hole, where are you measuring from? You are more the welcome to come around and check both of my cars with your callipers.
