Spring relocation brackets
jordan
Hey guys I'm chaseing a set of offset brackets so I can fit a bigger wheel under the rear I'm mini tubbing the car as well the more rubber the better
WANTED offset brackets for the spring hangers
71Plym
Winnipeg, Manitoba, Canada
Offset brackets and hangers will get you 3/4" to 1", depending on the brackets. I don't think mini tubbing is necessary for that amount of offset; it was not necessary in my case. To take advantage of the mini tubs, you would want to relocate the springs into the frame rails. There are kits available to relocate the springs, or you can make the parts yourself.
Mancini Racing Leaf-Spring Relocation Kit
