craigbred
- Joined
- May 9, 2019
- Messages
- 26
- Reaction score
- 12
The rad. cap should have a check valve built in it. It is usually in the center of the bottom side. Mine is about the diameter if a dime. It should let outside air in (or AF from an overflow tank) when the pressure in the cooling system goes negative (cools down), and then check shut when the rad. heats and pressure builds. If that is stuck shut, when the cooling system goes negative in pressure, the biggest and softest hose will be the first to suck flat.
I don't really think this is your problem because the neg. pressure in a cooling system occurs when cooling down (not heating up on the highway), but it is easy to check.
Craig
Craig
