stringfellow_po
I got around to doing a proper alignment at the weekend but I seem to end up with too much caster (aiming for 5 deg positive caster, 0.5 deg negative camber). I have installed PST non-adjustable tubular upper control arms (checked they are installed the right way round with ball joint level with floor) and adjustable strut rods (adjusted as per instructions with 3/4" thread of eye bolt threaded into rod). I have no binding over full suspension travel.
When measuring caster (on left side) I get +3 deg camber at 20 deg steering angle to the left and -2 deg camber 20 deg steering angle turning to the right (pretty much lock to lock). This means I have 7.5 deg caster (taking the difference and multiplying by 1.5) ?
If I move the rear cam bolt outward to decrease the caster I cannot compensate enough moving the front cam bolt inwards to get enough camber as it is already fully in board (aiming for 0.5 deg negative). I could lengthen the strut rod but would have thought I could get the correct adjustment with the UCA ? Pretty much same readings on right hand side.
I have set the front end ride height fairly low (23.75 in floor to wheel arch) to match the rear (hotchkis rear springs)
I have power steering (for now) so no issues with turning. Just checking my methodology is correct before I look at adjusting the strut rod length ?
