crytough
Getting 15.6 volts from battery when car on. This seems way too high what do I look for as the problem ? 12.4 with of. Voltage regulator ? It's on a 1970 challenger
The regulator uses the case of the regulator to sense battery voltage if it hasn't got a good clean ground then the voltage will increase sometimes as far as 17 Volts.
Also check the Engine to vehicle frame ground strap the regulator ground should have continuity all the way back to the battery.
Thanks, just torched my starter relay, going to replace + volt reg.The regulator uses the case of the regulator to sense battery voltage if it hasn't got a good clean ground then the voltage will increase sometimes as far as 17 Volts.
Thanks for the adviceHi, I had a similar problem. The screws or bolts that hold the regulator to the firewall may be rusty, or the threads in the firewall rusty. I ended up adding a small ground wire, maybe 16ga. from under the screw head that holds the regulator to a 3/8 bolt that I put in on the back of the head. I also put a little oil or grease on the threads of everything electrical so they won't rust. The regulator must have good ground. Also, clean the contacts inside the plug that plugs to the regulator. I usually use a small twisted up piece of scotchbrite and some break clean to rinse.
With the car running, I normally like to see 13.5 - 14.0v on a fully charged battery, no lights on.
To add to the comments already posted the charging voltage on a fully charged battery should be 14.2 volts. Any resistance in the circuit can cause the regulator to increase voltage to try and overcome the resistance. Check all the grounds first, alternator to block, regulator to firewall, negative battery cable to block, battery cable pigtail to rad saddle. Also check that the battery posts to clamps are clean and shiny. It's a good idea to polish all these connections and put a little grease or Vaseline on the bare metal and then tighten them down. I have seen black battery posts create so much resistance that as you increase engine rpm the voltage would just keep climbing well over 20 volts ! As a professional auto electric and tune up tech for 40 years I have always coated battery terminals and clamps with Vaseline inside and out. Corroded cables and battery terminals are then a thing of the past and never have to be worried about again.
