Water Temp Gauge Install
VillaTA
Cincinnati
Looking for sender location on the Auto Meter water temp gauge install for my TA/340. Never done one before. Any help is appreciated.
Righty Tighty
Sahuarita, AZ
Usually you’ll just use one of the threaded ports near the radiator or heater hose, and sometimes you’ll need an adapter. I don’t currently have a picture of a small block application, so I can’t provide visual reference.
VillaTA
Cincinnati
Ok. Found the port. Next - the install says to run a ground wire to a reliable ground near the sending unit. Any ideas for a good spot to run that won’t look out of place?
Righty Tighty
Sahuarita, AZ
Others may correct me, but I’ve gone to the ground at the radiator support with no problems. Or if you have good access to the engine/chassis ground, I think that would also be a good option.
