What's involved with removing the wiper switch
marklfarkl
San Jose, CA
The windshield wiper switch in my 72 challenger needs to be replaced. What's involved with removing it? I checked the forums, service manual and Google and cannot find anything that details switch removal. Found lots of info on where to get the switch restored but not much on how to remove it. Any suggestions or tips would be greatly appreciated.
marklfarkl
San Jose, CA
Ok, since I hear nothing but crickets....I'll start tearing into it and post my finding here when I figure it out...
js29
lee center ny 13363
It's pretty basic, you should disconnect the battery, remove the screws for the dash light bar. I think you have to remove the instrument bezel first,then remove the panel ware your switch's are mounted. watch ware you unplug everything. there will be A metal plate that screws to the plastic switch bezel, the rest should be self explanatory. A factory service manual will help you with a lot of different aspects of your car, and are available on C-D. I found mine on E-bay. I hope this helps. Mark.
marklfarkl
San Jose, CA
Thanks. I downloaded the factory service manual and could not find anything about switch replacement. I was considering trying to clean/fix the switch. May be easier to just purchase a replacement so I can quickly swap it out. They sure ain't cheap!
marklfarkl
San Jose, CA
Found some very helpful documentation here...
Racer57
You do not have to remove the main set of gauges, only the switch panel. Also, when you lower the steering wheel remove the 2 nuts under the dash and only 2 of the three on the firewall. I've never had to remove the left trim panel either. Use some wide masking tape and lay it over the main panel near where the switch panel is to help avoid scratches. One of the plugs has a tab to hold it in place(forgot which one), the other two pull straight off. You will cuss trying to figure out how to get the switch panel out/in, but it will fall into place when "its" ready. :D
This is also a good time to check out your panel lights.
marklfarkl
San Jose, CA
Pulling it out was very easy once I knew how to do it. :)
Some photos for other newbies
Remove the three light bar screws.
2A21CrUNOtW9B05gacJREDpNUF8Q60xuOlYI_ThQsFWOcgY8hR1hSkqp0Zg_RfE7RcI7SBxwoyOSvni42w=w1596-h898-no.jpg
Light bar comes out easy
VZYsLMWeTaSrjGTwt1zEWcLgh7h5ZDirFLvdVW5_c9huzw04sWvGUCuR5bdrta71KUCRyC2aq0EAXX3UBQ=w1596-h898-no.jpg
Need to find out where I can find light bar replacement bulbs..
_17Vx7587Be-iGxS70Oy78F0aazMYHK16GXYsm6tW721JCBs4QjBpGHuTRF6ZEaqMBDUNWHsZbnVg3DgFg=w1596-h898-no.jpg
Remove these two top screws
idCx3gs_4aoxP8zjtZRUZEbi4bhTXSz5Pdxb7eb5h1awrJbmauh1EzZuCPLamljBYG-XkyFA8RWaS-mf_Q=w1596-h898-no.jpg
And these two bottom screws
C1rQZQ2nHMfSr24rbU2tYszmkCN6_JyY7mLEOiK1oYlhURo0PQVwSUzcEUoK7eodOhmgSsxEKo12AwIaEw=w1596-h898-no.jpg
And it pulls right out...
QObp_Bz0i_gWLyeg4BzXMkIfm-o-cYzmX0OuVf3hgQkddT_T5f_hRh7KOsreznU90lDCAowxeZMlSj6SbA=w1596-h898-no.jpg
Removing the switch connectors
t1isZSt8Ao5nJZy66ZEok6RZ6VDgXZ9hh3X8XrpHyF--FMJLDZYcWlgPoj_MMp1db8S93QWUZxuYqdJmJA=w1596-h898-no.jpg
4HV3truIzpyr7sepTHgvCSuus_YcPfA1rfDCA9IyoNrgvaHxS4UkVrds98KjceHyMUkfyFiBYJpt_Jb6aw=w1596-h898-no.jpg
There is a release tab you need to pop out. Thanks to Jim at www.jsrestorations.com for emailing me about this. Here are the two photos he sent me showing where the tab is-
Out comes the panel. The last item to be removed is the light socket
-M-PxrakTz9cuD5HanlLWtcleQtXtws5-Ibnu4xW6MLuk5su5A2d0vyzx991btoAnqf3_1dSJWPQLa_Tug=w1596-h898-no.jpg
Remove the screws holding the switch mounting plate to the switch bezel
7viOqlvW4XYJeMEHXtXpNTEz2QHWlJnNYzhgDFX5Z45Ydn5F30L1mMD4SbwPrx7R3dxbGji0cpn8Y-0nUg=w584-h1038-no.jpg
DOH!! Don't do this!
SLVVY-fb1OJTJLy6xji6nwVc8Rbn6Abhd68pDgQkO3CRC52w8h_Jm-6T9eb0wLxjQr_ItJT4o_NLiLTzmA=w1056-h594-no.jpg
