Where are the water temperature sender?
Shut
FL
Hello to all, I have the rally gauges and the water temp dont work. Where are the sender to check it??
Thanks and best regards
DetMatt1
Metro Detroit
Big block.
Small block.
Shut
FL
Thank you DetMatt1. Then I dont have the original sender because in this position I have an aftermarket sender to gauge
I need to change this aftermarket gauge because dont work. Can you recommend one that fit in this measure nut please??
Shut
FL
Shut
FL
its possible tan the sending units its fine but I dont know
the gauge that dont work is this:
Shut
FL
I can take a pic of the sending unit...
otherwise I can try to put the original sending unit and the original water temp rally gauge. its possible or its very difficult??
DetMatt1
Metro Detroit
''Made in Taiwan" there's your problem! Hook up the original under the hood to make sure it works before you install it in the dash.
Shut
FL
thanks!!! yes its true haha
I dont know where are the original sending unit (this is the problem) I can take pics and upload to see it
Shut
FL
I need a new water temp gauge. Can you help me with ones that fit in this lug please?
Shut
FL
Im looking for a aftermarket water temp gauge that fit in this lug
Shut
FL
Thank you moparlee appreciated
Shut
FL
Thanks to tell me the lug measure. In Spain we use a different measure system than the USA and its a problem haha
Shut
FL
Perfect!!!!! thank you very much moparlee
Shut
FL
AutoMeter is a good trademark gauges??
