Where are the water temperature sender?
Shut
FL
Hello to all, I have the rally gauges and the water temp dont work. Where are the sender to check it??
Thanks and best regards
Big block.
Small block.
Thank you DetMatt1. Then I dont have the original sender because in this position I have an aftermarket sender to gauge
I need to change this aftermarket gauge because dont work. Can you recommend one that fit in this measure nut please??
its possible tan the sending units its fine but I dont know
the gauge that dont work is this:
I can take a pic of the sending unit...
otherwise I can try to put the original sending unit and the original water temp rally gauge. its possible or its very difficult??
''Made in Taiwan" there's your problem! Hook up the original under the hood to make sure it works before you install it in the dash.
thanks!!! yes its true haha
I dont know where are the original sending unit (this is the problem) I can take pics and upload to see it
I need a new water temp gauge. Can you help me with ones that fit in this lug please?
Im looking for a aftermarket water temp gauge that fit in this lug
Thanks to tell me the lug measure. In Spain we use a different measure system than the USA and its a problem haha
Perfect!!!!! thank you very much moparlee
AutoMeter is a good trademark gauges??
