Which carb do I have?
Wisconsin
I bought a nearly new Holley carb and need some info on it. The numbers on the carb are 12R 10552B. Is there a place to type in the numbers and get the low-down on this carb? Any help is appreciated.
I would look for another number on the carb. A quick google search shows thats probably a casting #. Another guy on another forum reported the same number on his carb, which was a 750 but thats not the model number...
How about some information on the carb. 2bbl ? 4bbl? The number that you gave on here does look like a casting number. Look on the side of the air horn flange, this is usually where the numbers are stamped in and most often has the word "List" before the part number. Do you have a picture of the carb?
This is what I found under your number.
List #
84011-2
C.F.M.
750
Stock Jets
(F)75, (R)75
Power Valve
6.5
Type
4010
Hope this helps........:3gears:
