Wiring connectors problem
mopar70
Canada B.C
The connector coming out of the steering column has wires that are coming out. How do I fix this connector or is there a better solution. The metal pins in the connector that the wires connect to are really bad from being old and worn out. Cars been cutting out ignition and battery won't charge.
Just replace the two harnesses in the column. Not very expensive You will have the ignition switch and wiring, and the turn signal harness. Less than $200.00. bucks for both, for Factory quality stuff. Takes care of a lot of problems. The turn signal switch feeds the brake lights and turnsignals.
Any links or places that have them it's just the pin things the wires connect to I don't need to dump that much money.
You will either need a small puller or a long puller with 6" bolts to remove the crush can then you have to remove the upp housing & the lock plate to get to the ign switch , the turn signal switch is TW7 from Standard parts & is correct for all but 70 but by trimming the 4 way button can be made to work OK . Standard should have an ign switch as well .
