bullet18
- Joined
- Jan 4, 2017
- Messages
- 311
- Reaction score
- 97
Ok so i need to remove my steering coupler to install a u joint for my new column and i cant seem to get the roll pin out. I literally just drove 2 feet of 5/16 steel rod through the smaller hole and out the larger one and the pin didn't come out. The rod was literally press fit to the smaller roll pin hole. Do i need to drive it from the other side? It wouldn't make sense to me to drive it out the smaller hole. The car is a 70 challenger with power steering. I dont want to try the other side and just get the pin more stuck. Any help is appreciated!
. Like I said, I didn't think it looked like the roll pin was even still in there. Looked like someone had driven the coupler up tight to the steering gear. There should be about a 1/4" gap between the two. When you re-install everything make sure the shaft splines and the roll pin shaft groove are all aligned properly.
