Could it be an RE, either way it’d be the same for 318 or 360.That is a 46RH, which is the one you want.
great do you have an idea what year is it did it come from 318 or 360 magnum cuz im mating this to a 360 magnum is it a lock up or non lock up thank you
The 3 pin connector picture identifies it as a RH lock up. The RE has a 5 or 7 pin if I recall correctly.Could it be an RE, either way it’d be the same for 318 or 360.
I thing 318 magnum is differently balanced than 360 magnum
