SmudgeServices
long time lurker, first time post'r!
i'm having a perplexing situation i'm having with my 1970 dodge challenger and i'm looking for guidance/insight as to the problem and what direction i should go to fix it.
bearings went out in the third member a few months back so i pulled it out and had it rebuilt.
it is a mopar 8 3/4 rear (chrylser brand - not aftermarket), 489 case, 3:23 with sure grip 'cone' type posi. it was rebuilt by a local shop where they replaced the ring and pinion gear and used a bearing set to replace the bearings throughout the differential. since the car was apart, i replaced the axle bearings with the green style, replaced the rear shocks, and put on new tires.
i put the car back together and tried to read all i could about the best oil to use. there is so much conflicting information so i just used "Mobil 1 Synthetic Gear Lubricant LS 75W-90 (Limited Slip Friction Modifier Included)" from the local parts store. in attempting to break in the differential properly, i drove about 15 miles <40mph with no issues and let the car cool. since then, i've taken it out to drive about 20 miles each trip to get it hot and then let it cool. but that's where the problem arises:
once the differential gets HOT after i drive for a few miles at 55+mph the posi starts making nasty noise when i slow down and make turns. especially sharper neighborhood turns. it's a growling type sound and it feels like the axle/wheel is skipping, getting caught up, or grinding in there. when i straighten out and continue driving it goes away until i go to make another turn. seems like both sides make the noise and it happens both turning left & right (but again, only after it's hot). if i let the car cool down for a day and take it back out, it's the same story--- quiet until it gets hot from driving 55+mph.
as per Dr. Diff's site, i purchased some Ford Friction Modifier (assuming the mobile 1 limited slip premixed in the gear oil just wasn't good enough) and added it but the problem continues to happen. it's been a total of about 100 miles since rebuild. i've driven it in 20 mile sessions to heat up and cool down but the problem persists. i'd say it's "gotten slighly better" since adding the ford friction modifier but certainly is still blatantly there and nasty growling.
any ideas or suggestions? the shop which rebuilt it is not responding to my calls. any guidance would be extremely appreciated. i just want to be able to cruise again! it's a hobby car and i'm no mechanical expert.
