Fender Tag
NorthStar71
MN USA
Pulled the tags off my fender, haven't found the broadcast sheet, and looking for some tips on best way to preserve/ refinish the tags - without destroying them. Also used an online decoder at Stock Mopar, posting here if anyone can fill in the missing "not found" options 16129090326299081584261874509422.jpg
NoCar340
Upper MI
The upper right code on bottom tag is "CTD" - codes are ConTinueD on the next tag. The code at upper left of upper tag is "26" calling for a 26-inch radiator opening in the core support as (opposed to the 22-inch cutout).
NorthStar71
MN USA
Thanks! Those were the biggest ?? I had
H6XW is the interior , I don't have the book here to decode it but it would tell you buckets or bench , console or not & color in your case W white
Cuda Hunter
high mountains Colorado
That is one sweet stacked up car! Sure aren't many two tag cars out there. Hope you find the build sheet. I'm sure this car has a few hidden gems.
Cuda Hunter
You can have new tags made since you have those. Or you can soda blast them , prime and paint them and put them back where they go. On the car for sure!
NorthStar71
MN USA
Thanks!! I swapped out the white interior as a kid & probably threw out the sheets, without knowing :oops:
Cuda Hunter
awh, that's too bad. That white and black interior is pretty uncommon in comparison to the standard black interior.
There is always the chance behind the glove box. possible headliner or under carpet.
Cool car!!
Culvers
Could you post a photo from the backside. It is hard the read if it is V6X or V5X...
NorthStar71
MN USA
Cool car!!
Oooh yeah, haven't pulled either of those yet 🤞
NorthStar71
MN USA
I'm a little confused on the spoiler package, car still has gull wing, but never had rear window louvers or chin spoilers - is that J68 & J78?
Shouldn't it have holes on fenders or roof?
NorthStar71
MN USA
Was on phone & tablet, feel like an idiot after finally getting on my pc and seeing the Decoder page :realcrazy:
Cuda Hunter
J68-backlite louvers
J78-front spoiler
J81-Rear spoiler wing type
Yes there are a few holes for the louver mounts.
Yes there would be holes for the spoiler mounts.
Easy thing to fill, or does the car have a repaint?
Cuda Hunter
J68 would have always had a vinyl roof.
The fc7 car does not have the correct rear window trim for a backlite louver.
the mopar picture with the pretty woman appears to have the correct window trim under the louvers.
