Replacement Wiring Connectors
RayL
NJ
I plan to cut out some of the PO wiring hacks and am looking for a source of the molded connectors. Are these available?
Also, where are the best places to buy colored wire? I've found "Marine" tinned copper wire on Amazon, but have no idea if this is a good choice.
Thanks everyone!
I do not believe those connectors (3 hole) are available, i have looked for them but never found any. I normally scavenge some off of old harnesses. The problem is that they are molded so you would need a pigtail, its possible that someone makes one but again I have never found any.
Same here, I’ve saved a few over the years but, never seen them sold separately. I have some of each and can’t part with them for fear of having to buy a new harness if I needed one.
Same here to. I tried some of the wire harness sites, but get nothing. What would you consider an acceptable replacement given the OEM connectors are not available? I've thought about splicing a 3 pin connector into the circuit with some creative soldering / shrink wrap work. Not even close to OEM, but would eliminate the open / short circuits I have now.
Amazon product ASIN B08DLJK8XW
I also have been looking everywhere for these. I have not found any. I did find some harness's that use them. I have been taking them off my old harness. If you find them, let us know.
