Steve340
I saw a factory diagram which showed a small square sealing adhesive strip applied to the cowl top to seal a hole that is partially under the cowl rubber seal.
The hole is in the upper cowl panel somewhere near the last two clips on the outside of the curve in the rubber on both sides.
I cannot find it again - it may have been posted here also. Tried a search but no luck.
My question is:
Is this adhesive square body colour - in other words was it applied then the body painted?
Or - was it stuck on after painting?
Thanks Steve
My question is:
Thanks Steve
