- Joined
- Oct 17, 2011
- Messages
- 7,281
- Reaction score
- 2,074
Take some photos of the complete caliper, bracket set up. What are the casting numbers on the original calipers ?
Fill through the hose hole with a penetrant like WD or PB Blast or whatever you like. Let it sit at least 24 hours caliper face down.
Use a C-clamp and an old brake pad to compress the piston. Once you get the piston to move, remove the clamp. Put the pad on the outside and stuff rags etc... between the piston and the pad. Using an air hose nozzle, apply air to the brake hose opening to force the piston out of the caliper. Keep your hands/fingers out of the area.
