1970 Challenger console automatic shifter
DY31970
Hi, Is the automatic console gear indicator supposed to light up?
tonysrt
If you have owners manual see if they list a bulb for it.
Yes , there is an orange wire under the carpet to the shifter , it will dim with the dash lights also
EW1BH27
Canada
Picture from the service manual. Edit: found better pics.
DY31970
Thanks tonysrt, Chryco Psycho. Thanks EW1BH27 for the service manual pictures. I'll check the light bulb and wiring.
Kez
San Luis Obispo, CA
Does anyone know a source for the tape used by the factory to tape wiring to the body - as shown in the picture above? It has some sort of paper backing - have seen it called electrical tape but it’s not the same as the vinyl electrical tape I know. Want to make sure I use the correct tape on my car - especially for the done light wires above the headliner. Thanks!!!
I used the 3M blue painters tape and rattle canned it with flat black before putting it on. Worked great and looked nearly exactly like the original stuff.
MoparCarGuy
2" x 60yd black masking tape on Amazon for under $10.
pschlosser
Santa Rosa, California
Gaffers Tape would be the way to go. Something like this from Amazon:
Amazon product ASIN B07K1WW8WW
its a strong cloth tape, designed to NOT leave a sticky residue. Pretty nice stuff, used for taping wires to surfaces, and would be ideal in this application. It should hold up well to repeated heat caused by headers, for those afflicted.
That said, it's unclear how factory original this is, but I recommend this over a masking tape, painted or not.
Kez
San Luis Obispo, CA
As I recall the tape I removed was paper backed - like masking tape. But masking tape would have medium duty adhesive. The Gaffers tape would probably be stronger and it will be hidden in most locations.
