Playtimefun
Good day folks
I am going through the process of re-building a 340 for my 1973 Cuda. I have to rebuild it due to stupidity on my part. We put Hughes hydraulic roller lifters in, combined with Comp Cams Pro Magnum Shaft mounted roller rocker arms. Which when i called were not supposed to be oiling through the pushrods. So we also put in some comp cams 8311 6.8" 0.080 oil restriction push rods. Well guess what... put all the oil from the stock oil pan into the top of the motor (especially when i was driving it hard) and spun bearings.
So now i have gotten a Milodon 30936 (7 qt) oil pan to increase the oil capacity and custom push rods from smith bros. with a 0.02 restriction. This way there will be still some oil going through the roller tips with the majority of it going through the shaft but according to Smith Bros. it should be only about 15% of the flow that the other push rods had.
I also ordered the Mildon windage tray thinking that it has to be a better fit that the old windage tray was. But now that I look at them, it sure appears that the old stock windage tray is actually longer and looks to have better coverage (maybe not as may cuts in it) than the new windage tray. Any thoughts on whether Ma Mopar got it right to start with? Is the old one actually better than the new models? I will take and upload some pictures shortly. Now this is not a stroker motor, so crank clearances are not an issue.
Thoughts?
Thoughts?
