1970 cuda build sheet read out
gf7cuda
Do they have a 1971 build sheet decoder?
MoparCarGuy
I don't think so, but not a lot changes between 71 and 70.
Someone correct me if I'm wrong please.
Correct. The 1970 E-Body decoder took a major amount of programming to create.
A 1971 decoder would be nice.
Use the 70 decoder and modify the PDF items that do not match up after you get them.
Change the date, etc. and you have what you need.
Options page: 1970 Mopar E-Body Option Codes
Cuda Hunter
high mountains Colorado
That sure is a lot of work that Cody put into that decoder system.
Quite the resource that he has made available to all of us!
Very appreciative!
440WB
Michigan
No doubt lots of hours!
I went and took a couple of pictures of the car today
Speaker deck tray here is black however, it does not look factory
440WB
Michigan
Black seatbelts like you said
Also in this car the A pillars are black
It was dark hard to see the trim
when I took the picture
440WB
Michigan
also in the rear picture you can see all the glass is tinted
440WB
Michigan
black steering wheel
dash pad looks good in this pic
would have to wash it and look in the sunlight to see for sure -
the good is allot of the original trim parts are in the car even thou some of it is removed.
super nice am fm push button radio -
all dash trim in place with all wiring
440WB
Michigan
this is a FE5 color car -
shows factory red color inside a pillar hinge area.
you can see it was repainted orange
and very heavy layers over rust pitting of floors and all -
440WB
Michigan
disk brakes are complete with sway bar and K frame has the welded corner in front
power brake booster
manual steering box
tail panel chrome trim in place
hood pins are there
torque box's
440WB
Michigan
the person says it was in accident and sheet metal was replaced - would be why she has no fender tag- no screw holes in inner fender -
440WB
Michigan
most likely the parts changed inner fender with fender, driver door, the full firewall with upper cowl and radiator support ( front frame ? ) might be why dash with all is now regular ???
with the whole body repaint ???
Insurance job???
person says car has been in the family for 40 years - they are second owner.
stamping numbers probably stamped from auto repair center - they are not very deep - one digit is off - out of line
440WB
Michigan
ink stamp back side
he claims accident was early 80's
440WB
Michigan
parts needed for the restoration -
trunk pan
passenger fender lower patch or change
both lower quarters
driver door skin
driver headlight grille bucket
front valance
upper insert
fog lamps
windshield
seat covers
all interior panels may be useable
headliner - carpet
would have to buy -
dana rear end
trans
motor
6 pac set up
shaker hood with set up
radiator
rebuild disk brake calipers
send out power booster
new rotors new front end parts
new gas lines with tank
new brake lines with shocks
leaf springs are low needs re- arched
magnum wheels
go wing?
probably an easy $35k plus body paint work
MoparCarGuy
Your car came with the R11 AM Radio which has chrome buttons as below.
The radio in your picture is not a 1970 radio. The 1970 R35 AM/FM is a thumbwheel radio with chrome buttons. The radio in your picture is from a later model E-body with the R35 AM/FM radio option. Black pushbuttons were not used in 1970. Later models did use the black pushbuttons.
440WB
Michigan
the radio is another thing that was changed -
ofcoarse!
