Engine issues
open headers
massachusets
Ok so I just replaced my 340 to a 360 magnum. At 2200 rpm’s there is metal rattle noise. Like a heat shield. Sounds like it’s at fire wall. Every thing is tight. Can’t find it. Driving me nuts. Any thoughts
Did you use either a 360 flex plate or 360 balanced torque converter? That's about the rpm an out of balance condition will really start to rattle.
Are the Tq converter bolts too long & contacting the plate ?
Possible exhaust leak ?
Right sound & location so I agree , you may have to bend the plate a little for extra clearance but I have often seen this especially when using a 10 " converter instead of 11" as the bolts sit further in on the radius .
Ricks72Chlgr440
Sisterdale, Texas
Exactly! Had the same issue. Found the TC bolt heads were scraping the inside of the inspection cover.
open headers
massachusets
Ok found it. So at higher rpm the flex plate rubbed the starter. Ughhh. Ground starter down a little. All set. Thanks guys.
open headers
massachusets
So now I’m breaking in new 360magnum. She’s running at 183 temp. And it’s 70 here. What’s average temperature it’ll run at.
Depends on the engine build, tune, cooling system type. Many variables that you didn't tell us, only that it is a 5.9 Magnum.
A normal , accurate gauge reading would be around 190-200°.
