Hello,
Need a little help. Recently I had my Rallye gauges rebuilt. Started the car, the oil pressure gauge pegged H and even after I removed the wire, stayed there.
After a while it dropped down below L and has not moved. Diagnosis shows that there is 4.96VC at the wire and while the car is running I see 41 Ohms from the tip of the sending unit.
My guess is that when the gauge pegged, it broke the pointer and dropped. Here is what I have installed;
Melling M63 oil pump, Standard Motor Oil Pressure Gauge Sending Unit.
Q1 - What should the sending unit resistance be while - Off/Idle/Just Started
Q2 - Any suggestions to replacing the sending unit if its not a correct one? Or something that is proven to work?
