High beam to cold air conversion?
73E
CT
Has anyone heard of a high beam headlight to cold air inlet conversion for 71 Cuda?
6PKRTSE
Using a 442 dual dryer vent air cleaner.
73E
CT
Never was a factory item if that is the question. You must fab it up yourself.
Yes, figured that. Thought maybe someone hasdone already. Also, wondering if there’s an actual part for the high beam whole.
Steve340
New Zealand
For the extra power it will make you might be better off keeping high beam lights if you drive at night.
If you are doing a race car that does high speeds it might be worth it.
challeng61
I would look a modern Challenger setup and also do a bit rewiring to make existing headlight high/low beam and halo intakes and use both high beam holes.
