Press Fit Studs for Master?
texski
Texas
Looking for a temporary solution that has lead to a bigger question. Masters come with 4 holes. The one I took off has 4 press fit studs. Raybestos list a hole size of 0.354", and McMaster list 5/16 studs needing a 0.311 hole a difference of more than 0.040. Raybestos was no help.
What are these studs and where can I find them?
Thanks,
Mike
texski
Texas
I need the ones that fit the 0.354 holes. It will be an aftermarket master. So not concerned with resto-perfect.
Front?
Mopars & Missiles
Manual brake cars have the "studs" pressed into the master cylinder, whereas power brake cars have the "studs" in the vacuum booster instead of the master.
I believe the OP has a manual brake car and needs the "studs" for the master cylinder, not the booster.
DaveBob
Thanks,
Mike
Instead of pressing studs into the master cylinder, I made stud plates that I installed from the interior side. I needed these after switching from power to manual brakes and an aftermarket master cylinder. The studs are actually bolts that are threaded into a 1/4" thick plate. Looking from the engine bay side, I have four studs to mount the master cylinder and two studs above the master cylinder to mount the wire looms.
Mopars & Missiles
Instead of pressing studs into the master cylinder, I made stud plates that I installed from the interior side. I needed these after switching from power to manual brakes and an aftermarket master cylinder. The studs are actually bolts that are threaded into a 1/4" thick plate. Looking from the engine bay side, I have four studs to mount the master cylinder and two studs above the master cylinder to mount the wire looms. View attachment 137818
Very nicely done! Where there's a will, there's a way. :thumbsup:
mayhem
Pacific NW
And that's what hot rodding is all about! What is it they say about necessity is the mother of invention?! Good on ya!
Katfish
Palm Bay, FL
Very nice, many moons ago on my first Challenger, the rebuilt MC didn't have the the studs.
I just put in some bolts, had to have a friend hold the socket inside, while I tightened them up.
We didn't know or care about "originality" back in the 80s.
