enforcer505
Hi Guys,
I purchased this Jegs disc brake conversion kit below:
https://www.jegs.com/i/JEGS/555/630200/10002/-1?year=1970&make=DODGE&model=CHALLENGER&submodel=BASE&engine=V8+(+5.2L+/+318+)
My 70 Challenger has manual (no booster) 4 wheel drums with stock distribution block (single big block) and 14 inch rims. brake system is all new and rebuilt.
I swapped the front brakes to this kit- but finding the brakes seem to be overheating. Ive done many of these kits in the past- Ive checked everything!
1- Caliper bolts are torqued and not holding the calipers from moving (jacked the car up and the wheels spin fine and when the pedal is pushed grab nicely and release fine also.
2- Replaced the Master cylinder to a manual disc brake type- the system is bled and no air at all in there and has a great pedal feel.
3- Calipers and pads arent dragging at all... but when rolling down the road progressively start to heat up (can feel in the pedal increased pressure and resistance and less pedal travel).
4- I purchased an adjustable rear proportioning valve for good measure and its installed. Rears were bled and no air in the system.
5- Im using the stock distribution block- Im assuming this is fine- it seems to work fine with applying and releasing the pads.
Ive replaced this kit once and Jegs sent another kit thinking there was an issue with calipers sticking but the brakes seem to heat up to much again.
Whats left is the distribution block to replace.... but whats frustrating is it doing its job fine....
Im completely lost on this and frustrated. Any guidance would be great!
