What shocks to use with super stock springs?
TIMINATOR
Avondale,AZ.
Well after some modifying I finally have the superstock springs in my 72 Challengrer.
When I built the car for a customer back in the 90s, I forgot that I moved the rear springs inboard, and since they were moved farther than the kit spring setup, I had to cut and redo the superstock hangers. Now I wonder what shocks work best with these springs?
I figure that I want a shock that is loose in extension for ease of chassis separation, but not sure. With all of my other A bodies, I just used what was on the car and they worked fine, but those were only 11 second small block cars. I have a set of new KYB gas adjusts that I got in a big trade deal, but if there is something better, I'll buy them. I plan on running 9 somethings in street trim eventually.
Thanks for any info!
TIMINATOR
Seems like QA1 and Bilstein fully adjustable shocks are what most folks are using these days. The Challenger Hellcats and SRTs use Bilstein from the factory. I noticed the son's Scat Pack has Bilstein as well.
The SS springs will create more body rise than original, so you need shocks that are at least a couple inches longer than stock to avoid topping them out. The common go to way back when was Imperial shocks. In the 80s, using Rancho adjustable truck shocks came into vogue for a while. These days, there are numerous quality shocks out there in fixed rates or in single or double adjustable that can provide good ride control. Just make sure they are longer than stock.
I was at a swap meet Sunday and a Mopar fanatic was moving out of state and sold MD a TON of new motor and chassis parts!
In them was a brand new pair of 2" longer KYBs. Put them on yesterday and time permitting I will drive it today.
Now I need an 8-71 or bigger to go on the blower manifold too! I have the drive setup, and carbs, an 8 is a bit small for the 512, so I will see what is out there.
I've had great results with Rancho 9-way single adjustables. Cal-Trac appears to have used or still is using relabeled Ranchos. They are a good, HD, stiff shock. The harder a car leaves, the stiffer the shock needs to be. It will control rise & spring wrap-up. OEM style truck shocks, even old race shocks are too soft. Too much separation is not good. Had QA-1 shocks single adjustable up front w/6 cyl bars to work with the rear.
I lost track of Rancho's spec page which gives compressed & extended lengths as well as bushing sizes of all their part #'s. I believe they started RS-999**** and they had about 3 different lengths. Their part #'s were grouped pretty close together.
Never been a fan of KYB , if the springs are moved inboard I doubt you will need longer shocks as the shocks will be be more compressed with the lower mount inward .
QA1 Rancho & Bilstein are all great shocks , definately want adjustable to control the rise tho .
I knew someone had to be using them.
79 Ramcharger 4wd front shocks were close to the challenger rear shock. I think they were an 1" shorter.
shocks rear
Challenger
KYB KG5512 Specifications
Compressed Length 13.98 in.
Extended Length: 22.64"
Dust Cover Included Yes
Extended Length 22.64 In.
Includes Bump Stop No
Internal Rebound Bumper No
INTERNAL REBOUND SPRING No
Lower Mount Type E1 L/E(17.5) 0.68:
Stroke Length 8.66 in.
Upper Mount Type E2(12.8x41.3)
Ramcharger front
Collapsed Length (in) :13.78
Extended Length (in) :21.43
Collapsed Length (mm) :350.0 13.77"
Extended Length (mm) :544.2 21.42"
Lower Mount Type :Eye 17.5mm 0.68"
Upper Mount Type :Eye 17.5mm 0.68"
Internal Design :Monotube
Finish :Yellow Paint
Reservoir :No
Body Design :Smooth Body (Non-Coilover)
Body Diameter (od) :2.0 in.
Piston Diameter :46mm
Boot Included :Blue Bellows
Spring Seat Included :No
Shaft Diameter :14mm
79 Ramcharger
GABRIEL G63353 Specifications Bilstein 16234DRJH 4600
Boot Included YesB6
Collapsed Length (IN) 14.96
Extended Length (IN) 24.74
Gas Charged Yes
Installation Hardware Included Not Required
Strut Mounting Type (Lower) Eyelet
Strut Mounting Type (Upper) Eyelet
75 charger
MONROE 58577 Specifications
Dust Shield Yes
Extended Length (in.) 22.500
Upper Mounting Description Loop Bushing & Sleeve Mount - 1/2" Sleeve ID X 1.5/8" Sleeve OAL
Lower Mounting Description Loop Bushing Mount - 11/16" Bushing ID X 1.9/16" Bushing OAL
Compressed Length (in.) 13.750
Travel Length (in.) 8.750
Spring (Rate) V/R
Parts Pack(s) None
Compressed Bumper Stop No
Extended Bumper Stop No
Extended Hydraulic Lockout No
Dust Shield Material Metal
Viper shock 93
Product Specifications
Brand Genuine Mopar
Manufacturer Part Number 4709388
Part Description Shock Absorber, Rear
Other Names Coil Spring, Shock, Shock Absorber, Spring
Item Dimensions 6.1 x 4.4 x 22.5 inches
Item Weight 14.30 Pounds
Position Rear
Condition New
Fitment Type Direct Replacement
Manufacturer Mopar
SKU 4709388
Rancho RS5000X RS55005
rear 4WD
Adjustable DampingNo
Body Diameter2.251
Compressed Length (IN)17.24
Dust Shield IncludedYes
Extended Length (IN)29.01
FinishPainted
Gas ChargedYes
Hydraulic LockoutNo
Includes Bump StopNo
Internal Construction TypeDual Tube
Internal Rebound BumperYes
Lower Mount CodeL2
Lower Mount TypeLoop Bushing Mount - 11/16" Bushing ID X 1.9/16" Bushing OAL
Shock Absorber Bore Size (mm)35
Travel Length (IN)11.77
Upper Mount CodeLS39
Upper Mount TypeLoop Bushing and Sleeve Mount - 1/2" Sleeve ID X 1.5/8" Sleeve OAL
Rear RWD RANCHO RS55116
Boot IncludedYes
ColorWhite
Compressed Length (IN)14.86
Extended Length (IN)24.05
FinishPainted
Hydraulic LockoutNo
Lower Mount CodeL1
Lower Mount TypeLoop Bushing Mount - 5/8" Bushing ID X 1.5/16" Bushing OAL
Shock Absorber Body End Measuring PointEyelet
Shock Absorber Rod End Measuring PointEyelet
Travel Length (IN)9.19
Upper Mount CodeL1
Upper Mount TypeLoop Bushing Mount - 5/8" Bushing ID X 1.5/16" Bushing OAL
KYB MOUNT DECODING
Code Description
ID Inside diameter
OD Outside diameter
E1 Eyering with 5/8" ID rubber bushing
E1 - L/E Large eyering with rubber bushing. The (xxx) after L/E is the bushing ID.
E2 Eyering with bushing and metal sleeve The (xxx) after E2 are the sleeve dimensions. Example: (12 x 32) = 12mm ID x 32mm wide
E3 Eyering with slotted barpin The (xxx) after E3 is the barpin slot dimensions & rotation. Example: (48 x 80 x 0) = 48mm from slot ID to slot ID, 80mm barpin OD, with 0 degrees rotation. (means barpin is perpendicular to shock body)
S1 Standard 3/8" / 10mm OD stem (bayonet) mount
S1(xxx) Stem with special dimension Example: S1(12mm) = 12mm OD stem
S-BRKT Special bracket with studs
RANCHO RS994005 Rear 4WD
Active or Passive SuspensionPassive
Adjustable CompressionYes
Adjustable DampingYes
Adjustable ReboundYes
Adjustable Ride HeightNo
Air AdjustableNo
Air Ride SuspensionNo
Bearing Plate IncludedNo
Bladder Heavy Duty Crimping Rings IncludedNo
Bladder Sleeve(s) IncludedNo
Bladder(s) IncludedNo
Body ColorSilver
Body Diameter2.38 IN; 60.5 mm
Body MaterialSteel
Boot IncludedYes
Coilover Springs IncludedNo
Coil Spring Insulator(s) IncludedNo
ColorSilver
Compressed Length17.6 IN; 447 mm
Cylinder ColorSilver
Cylinder FinishPainted
Cylinder MaterialSteel
Cylinder Outside Diameter2.38 IN; 60.5 mm
Damping Adjustment TypeManual
Dust Shield ColorRed
Dust Shield Diameter2.99 IN; 75.9 mm
Dust Shield MaterialRubber
Extended Length28.67 IN; 728.2 mm
FinishPainted
Gas ChargedYes
Hydraulic LockoutNo
Internal Construction TypeTri Tube
Internal Rebound BumperNo
INTERNAL REBOUND SPRINGNo
Lower Mount CodeL2
Lower Mount TypeLoop Bushing Mount - 11/16" Bushing ID X 1-9/16" Bushing OAL
Maximum Ride Height Lowering Distance0 IN
Maximum Ride Height Raising Distance0 IN
Mounting Hardware IncludedYes
New Or RemanufacturedNew
Parts Pack(s)P00934
Remote ReservoirNo
Rod Diameter0.709 IN; 18 mm
Self-LevelingNo
Shaft MaterialNitrocarburized
Shock Absorber Body End Measuring PointCenter of Loop
Shock Absorber Bore Size1.26 IN; 32 mm
Shock Absorber Rod End Measuring PointCenter of Loop
Shock Stroke11.07 IN; 281.2 mm
Spring IncludedNo
Spring Isolators IncludedNo
Spring Seat IncludedNo
Strut Mount Insulator(s) IncludedNo
Travel Length11.07 IN; 281.2 mm
TypeTelescopic
Upper Mount CodeL1
Valving TypeProgressive
RANCHO RS994116
Air AdjustableNo
Body ColorSilver
Body Diameter2.37 IN; 60.3 mm
Body MaterialSteel
Boot IncludedYes
ColorSilver
Compressed Length15.06 IN; 382.6 mm
Cylinder Outside Diameter2.37 IN; 60.3 mm
Extended Length23.76 IN; 603.6 mm
FinishPainted
Gas ChargedYes
Hydraulic LockoutNo
Lower Mount CodeL1
Parts Pack(s)P00916,P01013
Remote ReservoirNo
Rod Diameter0.71 IN; 18 mm
Self-LevelingNo
Shaft MaterialChrome Plated
Shock Stroke218.7 mm; 8.61 IN
Spring IncludedNo
Travel Length221 mm; 8.7 IN
TypeTelescopic
Upper Mount CodeL1
I have used Rancho 9 way adjustable shocks in the past that seem to work just fine. Since you have moved your springs inboard these shocks would be long enough and should not need the usual shock extenders needed when super stock springs are used.
