No problem at all..Thank you. Much appreciated!
Not pictures of my vert, but ones I have saved over the years. Hope these help. I think these are from a '70 barracuda/cuda vert. Not sure what site I downloaded these from or who posted them. Thanks to the original poster whomever you are.Alright, all my vert fans out there, does anyone have close up detailed pictures of this area? I need to reconstruct quite a bit of it.
Hope these can help you. My Verts in Paint/Body Prison currently or I would get you better photos.Alright, all my vert fans out there, does anyone have close up detailed pictures of this area? I need to reconstruct quite a bit of it.
I will keep searching my computer.
Hope these can help you. My Verts in Paint/Body Prison currently or I would get you better photos.![]()
moparconnectionmagazine.com
Yes, you should have x braced the door jams from the inside before you started. I would triple check all of the door openings at this point and maybe even re-mount the door hinges and doors to confirm that all still fits and functions as it should now before you weld back in the new metal.
these cars flex, I think the convertible more so than the hard top. The flex may be related to where we lift a big block car, too. I've seen the reveal (the gap) around the doors change after lifting the front of the 440 hardtop car at the K-frame-sway bar area, and I can get it to return to normal by lifting just behind the front wheels, at the fender to cowl area.
if you're straitening the frame, you may do so without the engine and trans installed. But if this is a big block car, perhaps with auto trans, things may change again once you get everything bolted in place. so be prepared for some late tweaking of the doors, if you're seeking perfection.
In contrast, a 1970 Barracuda 318-2 Convertible I drove for a time didn't seem to move at all, when varying the lift points. So this may be more of a big block issue than with small.
From the bottom of the frame to the top of the door sill. 6.2 " Here's a blank to work with.
