Master Cylinder mounting
1moretoy
Bay Area
Hey all, I'm going to run an electric power assist master cylinder and need to figure out a way to mount it. The master cylinder is a standard 2 hole but I have multiple holes on the firewall. It's been a while since I took the car apart and of course I can't find the plate I had. Does anyone know where I can get one so I can mount the new master? Also, what do I do with the two studs sticking out above? I was thinking I could cut them, spot weld and grind flush?
I believe you still need the two studs above to help support the engine wire harness if you intend to install one.
