Borgeson Steering box question
GregD
I recently installed a new Borgeson power steering box in my 71 challenger. I haven't had a chance to drive much yet since i live in the northeast. I noticed after the install that the car wants to pull to the left pretty hard. I did some research and saw that factory steering boxes have a adjustability in the steering valve to find a neutral spot in the power assist. Does anyone know if the Borgeson box has the same adjustability? My car is in storage so i can't look at it. Trying to get me spring plan together to get it back on the road.
you bring up a good point. what if... when installing a steering box, the position of the steering system within the box is not at center? we put the pitman arm and the steering input shaft the onto the nearest spline and call it good.
I seem to recall there is a marking on the housing that tells us when the input shaft is aligned to center.
That said, I would not think if the steering box were off-center, it would provide forces bringing it back to some "center" point. I think it's usually the front-end alignment that introduced forces to pull left, right, and even back to center when completing a turn.
I did two, 74 Duster and 71 Cuda, and no problems. Could you have hooked up hoses wrong as a possibility?
I installed a Borgeson steering box on my Challanger and have not experienced any problems with it whatsoever. Everything else in the steering gear and front end is OEM and it drives perfect!
I would suggest having your alignment rechecked and be sure the caster adjustment is correct. That is the most common cause of a vehicle pulling to one side. The number two cause is a bad tire or low tire air pressure which i'm sure you have checked already.
Another person here suggesting you get the alignment checked. Search for a small independent shop that does alignments. I've had better luck with them than big chain places.
Before you make any changes, go to youtube and watch some videos on alignments. By knowing what measurements to make, you may just find that your alignment has changed. You are not necessarily trying to align the car yourself, only using the information to try to identify the issue.
Our Mopars do not use shims to align the front end and very few shops are familiar with them, so finding a shop that can do a good job can be difficult.
When I installed my new Borgeson box, it threw the alignment off.
Got one in my car, but haven't driven it yet. It is nice and compact. I got mine from Bergman with the matching slip joint unit. Went in nice. I have powered up the engine and the system did not pull the steering to one side or the other. Just sat there in the center. But I was also replacing bushings in it as well, so my alignment was off out of the gate and required adjustments to all angles.
The only thing a steering box change would affect is the toe-in and steering wheel straight ahead alignment, it would have no effect on caster or camber.
Adjusting toe is part of an alignment. Rather than try for a 'close' measurement with a tape measure, I went with the 'to the degree' that a formal alignment gives. And confirms (or adjusts) the camber and castor as well. Seemed prudent.
Okay, but your post would lead people who aren't that knowledgeable about front ends to believe that a steering box change would throw the whole alignment out of whack. I just wanted to clarify that it doesn't. Also, if the centerlink is at in the same plane it was with the original gearbox it won't effect the toe-in either.
I don't know, I can get damn close on toe-in (or out) with just a tape measure and a piece of straight steel bar. Worked great for years on our Challenger Street Stock race car. On a street car with tread, don't even need the steel bar.
In theory. If it was aliened with new or very good parts.When replacing all the parts or just one that wears, steering box, idler arm,ball joints,tire rod ends do one at a time and but back on the same thread. It would be back in alignment. I have done that and never had a problem. I have also done the caster and camber, But that can be a a problem. It's usually a ball joint I replace when it feels out of aliment. I have done that. Can not count how many times. The problem is every one takes everything apart and it's all out wack! And yes. I do both sides if it one doesn't fix it.
