Vacuum advance
ColoradoCuda
I know this has been asked 1 million times, but I have yet to find a satisfactory answer. I have a 71 Cuda with a very stock 383 and an Edelbrock 750 CFM carb. Should I go with the ported or manifold vacuum for my vacuum Advance? Also, any recommendation for initial timing with the vacuum Advance disconnected?
Such a simple question and so many answers. Mine would be. It would depend on how the engine is built and used, if advance is used at all. Requires Deep thought.:popcorn:
I would use ported and at least 6-10 initial.
I had interesting problem when I installed Fitech on my 340.
The gas mileage actually went down and I was stunned.
I found out the port on the Fitech throttle body is too high, and the vacuum advanced never kicked in at light throttle.
I switched to manifold vacuum and it fixed that issue and the gas mileage improved, as expected.
So my advice is, start with ported, and check it.
Assuming by Stock 383 you also mean a stock points type distributor, than yes, the ported vacuum port that opens up just after the primary throttle plates open up, is the vacuum port to use. At idle, you typically want no vacuum advance and full vacuum advance at highway speeds.
manifold vacuum
Manifold vacuum give a quicker response.
This is best for smoother transition and drivability. Just some of my 2¢, Others know how it works.
Only difference between ported and
manifold vacuum is it idle you're not
adding any ignition timing if you're on
your ported port.
I have some other sense. I give as it goes along. Or I could give long explanation. That I might do if thing go a muck.
The only difference between
ported and manifold itself is that
manifold adds timing at idle while
ported does not. If you have your
carburetor setup right and not too much
throttle exposure. So which one should
you use. Where should you hook your
vacuum line for your vacuum advanced
canister? Onto your carburetor ported or
manifold? Then to clear up one more
misconception about all this. A lot of
will move their vacuum line from
ported to manifold, manifold deported and
say well it runs better. Either way know if
you go to ported. You have to realize for
manifold you took ignition timing and
took it away until you have enough
throttle input. What you have to do is
advance your initial mechanical timing.
Make whatever assessment you want to
make and ultimately it's your choice.
What you choose to use.
Most all street engines
that have mild cams or stock cams work
the best on ported vacuum, They don't
require a whole lot of ignition timing
at idle. Because the dynamics of the
camshaft is just making really good
cylinder pressures at idle. Versus a high
lift cam with a lot of overlap. Doesn't
have as much cylinder pressure at idle
and requires more initial advance. If
you try and run manifold vacuum on a
mild cam or stock style engine. What
you're going to have happen. There will
be so much ignition timing being added
in from that vacuum advanced canister. That in order for your carburetor to idle. At the know ideal rpm. The throttle has to close way too much on the carburetor or you need to have way too little initial mechanical advance.
Then when you step on the throttle hard. You take that timing and throw it out
the window. You know just your
engine responds, very lazily off the line.
because now you don't have enough
ignition timing. So with ported you can
mitigate a lot of those issues. Of
course there is a dynamic relationship
between your ignition timing and the
functionality of your carburetor at idle
Again remember ported we need to add
a little bit more initial mechanical
timing. What you're looking for on your
carburetor settings. Is a throttle
position in between the point of where
your transfer slots are exposed. You
have a little bit of vacuum signal on
those. But not so far that you get to the
point. That is actually your ported port for your vacuum advance. If you get too much
throttle exposure and you're seeing
vacuum on that port at idle then you
have too much throttle exposure. Then you need to increase your initial mechanical timing.
If you go too far.
which most can easily do with full
manifold vacuum. You will see that now no
transfer slots are exposed. The
purpose of those transfer slots in
conjunction with your accelerator pump.
Is to handle the transition from idle to
your main jet circuit. They work a lot
better if they have a little bit of
vacuum signal. Because fuel is already
flowing. When you hit the throttle you know it just continues to draw more from that circuit.
If you have no exposure at idle. Basically you have a flat spot, between the time it takes from fuel to get going on that circuit before it gets to the engine. That's kind of
the form and function of how all this
works in a Holley and Edelbrock are
actually exactly the same. In this regard
the ported port. On Edelbrock
being up here because it's above the
throttle blades, in the same way it also
has transfer slots. You can set
everything up with the same mentality
between the both carburetor styles.
There's really no difference. I also
want to make it clear that ported vacuum
is not the end-all be-all.
there are compromises you have to make
with ported vacuum. You know even
though the advanced. (The initial
mechanical timing relatively to an idle.
The advanced is still a little late and
it's going to favor a richer idle
mixture. )
You have to make on both sides. I'm not
really in favor with either of them. But
for street engines I've seen that ported
vacuum works really well.
That's maybe why I think the Thermo quad. It was a stroke of geniuses. Didn't have to do much to it. It would adjust to it's demands. It would purr like a kitten, then you woke it up it would roar like a lion.
IMO simple as RPM rises the engine needs more advance so connecting to the manifold gives the most advance at idle when vacuum is highest & dropping as the throttle is opened so it is going the wrong way as more throttle is added meanwhile mechanical advance is going the other way increasing with RPM .
Personally I don't use vacuum advance at all , , I run a lot of timing at idle increasing with rpm through Mech advance using a short curve , I have made the best HP on the Dyno & mileage this way .
I have also tuned using EFI & Computer when timing curve can be adjusted every 250 RPM & found similar results .
My $.02 , take it or leave it .
