I believe Chrysler eliminated the residual pressure valves from the master cylinders in the mid 70s. There are expanders in the rear wheel cylinders now. I have an aluminum 1 1/32” MC from Dr Diff with front disc/rear drums and it works fine without the residual pressure valve. The Disc-O-Tech article mentions residual pressure valve elimination.
“In the mid-1970s, Chrysler eliminated the rear brake residual pressure valve from the master cylinder. Its function was to prevent any air from sneaking into the system via the rear wheel cylinder cups. In its place, Chrysler substituted "expanders" in the rear wheel cylinders. (Expanders are dish-shaped steel inserts that exert outward pressure on the cups.) If you should decide to use a master cylinder from a 1975-up car, be sure you have the expanders in your rear wheel cylinders. For at least 20 years they have been universal in all replacement wheel cylinders and rebuild kits.” From the Ehrenberg article.
