Rebuild kits for Brake Master Cylinder
michigan2023
Niles Michigan
Does anyone know of a source for rebuild brake master cylinder kits. I have a 72 dodge challenger with 340 4-speed that has manual front disc brakes. The Master cylinder is in good shape but the seals are in need of an upgrade.
Thanks in advance.
Steve W
SW Michigan
This has 1-1/32" bore
There are a lot of sources. Check your local Auto Parts Stores. Especially the small independents if there are any in your area. Napa is a good choice. I bought the one I got online for my 70 Cuda. Check Rock Auto, Amazon, etc. You should be able to find one. The bore of yours looks a little rough from the pic. You will need to hone that out to correct that issue. I sent mine out and had it stainless steel sleeved...Then rebuilt it at home in my Shop.
Yes…checked all the options you mentioned however I could only find complete assemblies…I ordered one from Rock Auto…haven’t received it yet. Even those you don’t get the dust boot or rubber ring for the push rod. Thanks for the suggestions
I sent mine to be stainless sleeved at a place in Minneapolis. ... Brake Equipment and Warehouse. Phone 612-378-3141. They also sell kits. They did a very nice job on mine...
You bolting that on?
Or was the plan to use the parts to rebuild your original?
I was going to disassemble it tomorrow to see if the internals are the same…if so I was going to use that to rebuild the original? Not sure the new aluminum one would hold up? It’s advertised as 12months or 12k miles.
I’ll reach out to that company in MN MoparMitch suggested next week.
After inspection the FVP has the same internal components as the original. All items spec out dimensionally.
The only concern I have is on the original there was a backflow preventer on the Rear line set behind the brass seat… the aftermarket does not have one.
Does anyone see an issues with not having this item? My origin still seems to work after cleaning.
Seems odd the aftermarket would not have this provision
Sw
