Congratulations
your Chally is lookin great now.
Greetings from Germany
Juergen
Thank you for the pictures!
I think I figured it out a few days ago.
I got the power steering all hooked up and the gas line run to the carb.
With the aftermarket Edelbrack manifold I had to modify the throttle return spring bracket.
What do you think about the Mopar blue air filter cover?? I don't know if I like it or not?
View attachment 17708View attachment 17709View attachment 17710View attachment 17711View attachment 17712View attachment 17713View attachment 17714View attachment 17715
(View from my front porch. The foliage in Vermont is really peaking out today.
Looks awsome ! What a view.... here were I live.... only houses...and pavement.
Back to your car.... the work you did the last days looks good. What Kind of QF did you use ? 680 VS ?
About the Airfilter.... I would go..and search for a 340 OEM Airfilter assy.... ( because your engine bay deserves it ! )
Greetings Juergen
I would go the electric fan route if you plan on attending car shows. They have saved many cars when you are doing low movement idling for extended periods of time. Manual fans just don't keep up at idle.
If you are open road all or most of the time then stick with simplicity of the manual.
Mike.
Hello Bill....
I would go the "OldStyle Way".... with a clutched Fan ! I don´t like the "E-Fan" because they Need a lot of "energy " from the alternator...you have to upgrade your wireing you Need a "bigger alternator and battery... the look isn´t realy nice... and the E Fan Motor can fail.
I allways used the Fan with a HD clutch.... my car runs allways 180° F doesn´t matter if I drive on the AUTOBAHN with 90 mph or sticking in the City traffic with 90 deg. outside....My car has the OEM 22 " Radiator...a 5 Blade Mopar Performance Blade and a HD clutch from Hayden.... and a fan shroud of course!
Greetings Juergen
concering the fuel economy I have to disagree btw. why ? Because the E-Fan uses also ENERGY coming from the Alternator...so the engine has to work "harder ".... so vs the Fan with clutch...it would be a win -win situation
