Guys - I have replaced my water pump (High Flow) , thermostat (185 Degree High Flow) - gauge is normally in the middle. When I stop the car I have water puking out of the overflow tube and a gurgling sounds coming from the engine. I have a 7 PSI cap on the radiator. I was told that I may have air in the system so I took off one heater hose and let the car run as I was adding water to the radiator. Everything seemed fine until I took it out for a long drive and bam it started puking water out again and continued to make the gurgling sound. Would a 16 psi cap help and what is the correctly way to remove air from my cooling system? Any help you guys can give me will be greatly appreciated.
