Frank VP Challenger
I recently completed restoration of a 1972 Challenger that someone had installed a 440 ci. 4 barrel with 727 transmission. The vehicle was straight, rust free and was a good candidate for a Vanishing Point (Kowalski) clone/replica. The alpine white paint came out great and I refreshed the black interior (headliner, carpet, door panels, etc).
The car had a noisey electric fuel pump on it. After ordering a new mechanical pump and starting the installation, I found out that the fuel pump push rod was missing. In addition, there was nothing to activate the fuel pump arm. It appears that the esentric lobe on the cam is not there. So, I'm assuming a newer later model cam without an esentric was installed - ? Anyway, I plan on ordering a new cam (with an essentric lobe) to resolve this problem.
Another issue that I haven't been able to pin point is a very noisey vibration while driving at any speed. I've had the drive shaft checked and balanced, the rear pinion reset, checked transmission and motor mounts - but the vibration remains -? The 440 engine is identified as a high performance 440 steel crank from 1969, and is balanced internally. So, I'm assuming the high stall torque converter is a neutral balance - no weights.
I would appreciate any suggestions on correcting this "out of balance" problem, or; any additional checks I can perform to pin point the problem. Thanks. Frank VP Challenger.
