borgeson power steering
michael bucklew
just installed the Borg. box and pump. my OEM pressure hose does not fit, to long. is there a off shelf hose that does or, do I have to get one from Borgeson
I had similar problems. While they advertise the kit as a bolt in, when I had issues and called, I was told that this is hot rodding and modifying parts is part of it. So, I had to fab up the return fitting myself as they has no other choices. Other issues were not as easy to rectify.
The Cuda does drive better than it did with the original box. BUT! Had I known of the issues that I would have had to deal with, I would not have done it.
return hose is no problem, it's the pressure hose that is a problem. question. two fittings. upper right and lower left.on the steering box. which is the pressure fitting----no instructions of any kind in the shipment
You did buy your Borgeson box from Peter at Bergman Auto Craft and got his kit with the proper fittings he machines, didn't you? If not, give him a call.
(516) 384-6438
i've installed 2 of them, no issues, Peter is a good guy you can solve it with a call and a credit card. I got a full kits with pump and hoses, all new is good, then its over, usually.
Same for me, Peter at Bergman Auto Craft is the go-to guy for the Borgeson PS swap.
Factory pressure hose fits perfectly with Peter's adapter fittings for return line and pressure hose from pump to box (see below).
Most have the Saginaw pump.
And the box clears TTI 1-7/8" 440 headers in case anyone is curious!
The Borgeson 925113 hose kit is to connect part #800126 or #800127 steering box to a Saginaw style pump.
mommy old hoses did fit.. hardest part was having to remove the left header...all parts fir....easy job
If the hose it the only problem it should not be to hard to figure out. I added power steering and figured the hose I needed and did some search and got one ordered at autozone that said it would not fit my car they called when it came in and it fit perfect and was not a long bulky hose they said would fit
Do you have the item number?
