borgeson power steering
michael bucklew
just installed the Borg. box and pump. my OEM pressure hose does not fit, to long. is there a off shelf hose that does or, do I have to get one from Borgeson
I had similar problems. While they advertise the kit as a bolt in, when I had issues and called, I was told that this is hot rodding and modifying parts is part of it. So, I had to fab up the return fitting myself as they has no other choices. Other issues were not as easy to rectify.
The Cuda does drive better than it did with the original box. BUT! Had I known of the issues that I would have had to deal with, I would not have done it.
return hose is no problem, it's the pressure hose that is a problem. question. two fittings. upper right and lower left.on the steering box. which is the pressure fitting----no instructions of any kind in the shipment
