11.75” disc brake upgrade
Fireman Dan
Evansville, IN
Doing a brake upgrade on a 70 Challenger project car. Ended up buying a pair of slider brackets and bolts on ebay. I used a ‘78 Cordoba as the “source” vehicle for calipers, rotors, bearings, etc. I re-read the disco-tech article to be sure I had all the parts. Then I noticed he said DO NOT use late B-body calipers. Ooops! What vehicle used single piston KH slider calipers with the hose attachment the same ad E-body ?
I believe the main issue is the type of connection at the caliper & the hose to use , it may take some research but I have een able to find a hose application to make it work , typically I have used 5TH ave parts for conversions .
The site or something is having issues. Can't read everything. But from memory. It might be you need a 1976 dodge dart caliper hose.
If this is the setup you are using. I would be 1976 dodge dart hose.
Fireman Dan
Evansville, IN
I believe that is what I have. I'm hopefully assembling in next several weeks. I ordered 76 A-body hoses per Disco-tech article
