340 six pac disc brake hose rub
Ledge70
My 70 T/A Challenger front disc brake hoses are rubbing on the shock.
NAPA and others replacements are 14 3/16" long. Still very taught though behind the shock and at times rubs during turning.
If I go around the front of the shock it's to short. I was told there are different hoses for two pistion (VS) four pistion? I believe I have a single piston caliper stock?Any advice or pictures of your Cuda or T/A Challenger brake hose locations would help alot
Read more: http://forums.moparmusclemagazine.c...ront-disc-brake-hose/index.html#ixzz1Sm5D2ApO
there were a number of different single piston calipers used with different locations & styles of hose connection , the calipers & spindles could also be reversed side to side putting the caliper either in front or behind the spindle . The 4 piston calipers/brakes were used up to 69 & were never used on an E body .
yours should be in front with a 2-3" long steel threaded end going straight into the caliper past the shock , pix would help .
