360 magnum throttle bracket
wilsum
virginia
I am looking at getting an 360 magnum style motor to put where my 340 is currently. Making up a parts list of what will not swap. For those that have done this already, what did you use for a throttle cable bracket? Since the intake bolts differently my stock la engine based bracket doesn’t look like it would work without some sort of additional brackets?
Mancini Racing stocks a lot of custom brackets for this type of thing , I would contact them .
Not too many intake choices. As far as the angle of the intake bolts, a good vice should be able to bend yours to 90° fairly simply.
Mancini does stock several brackets, not sure about the Magnum intake though.
Drivun
Atlanta GA
i used a Lokar cable with a Holley J shaped base plate. The Lokar bracket I first used kept rotating backwards.
Drivun
Atlanta GA
Finally got to shop and remembered to take photo!
