70 Barracuda Heater Box restore question
Barraguy
Dacula GA
The 2 heater box doors, after i removed the dry crumbled foam, I found a sheet of clear plastic between the foam and the doors. Should I remove this also, then spray the adhesive, or just spray over the top? I have never seen this mentioned before.
Hemihead2
Remove it and spray the adhesive. Worked well for me.
Barraguy
Dacula GA
Another question...... with the Detroit muscle technologies rebuild kit you get 2 of the foams i am pointing to, they are called: Charcoal foam strips that seal where the inner heat/cool door (#3) closes on the box. One obviously went where i am pointing as there was some tape still there that needed to be cleaned off the metal. Where does the 2nd foam go? I'm rebuilding a 9/69 heater box... could there have been a change that added a 2nd foam someplace?
Barraguy
Dacula GA
Give Loretta a call at DMT. She will be able to tell you.
I emailed them with the same picture and got this back on the 24th
Boy it’s been 10 years since I opened one of those boxes. I’ll dig through my old pictures and see if I can tell.
Jim Fillmore
Detroit Muscle Technologies
